I have an Elson Coral E thermal store with 2 immersions - one is a booster which I never use and the other is the main controlled by a timer. The booster immersion sits in the middle of the tank, the main sits under it near the bottom. After 3 years the booster immersion has just had to be replaced due to a leak. Had to drain the tank which was a nightmare! When I now heat water using the main immersion the noise is incredibly loud. The plumber I called back now says the leak damaged the thermostat housed in the main immersion and plans to fit another after the weekend. However will this solve the noise problem? I've read other posts suggesting air in the tank, kettling and thermostat problems could cause the noise. According to the system literature the builders left me there are 2 thermostats - a control thermostat and an overheat limit thermostat - should both be replaced? Any advice would be most appreciated.
