apart from making sure there is sufficient water in the system, theres not a great deal you can do yourself. maybe turn stat down or introduce a boiler silencer chemical into system if noise is from heat exchanger. might be worth chemical cleaning aswell.
would recommend you get a corgi engineer to investigate fan though.
