noisy shower pump
14 Mar 2009
West Lothian
I have recently had a grundfos stc 1.5 shower pump fitted and the noise is unbearable. It is situated right next to the tank in the airing cupboard. Can anyone suggest a quick and easy way to quiten this thing down?
thanks
This is my first time on a web forum and dont actually know if this is the right section of the web site. If not can someone re-direct me
The noise should not be that bad, is it sat on rubber or foam pads? This will reduce noise caused by vibration.
Also, make sure the flexible "anti-vibration" hoses on the pump have a little bit of slack, and that the pipes are clipped to stop them shaking.
If this doesn't fix it, as mentioned above place the pump on a rubber mat.
