Hello,
Woundering if i can get some advice.
This morning a friend and myself decided to replace the Radiator Valve's in my 3 bedroom house. ( i wish i had never started) we messed something up as we now have no hot water and radiators dont work.
I'll start by giving you an idea of what i have.
4 radiators upstairs.
3 radiators downstairs.
Valiant Combination Boiler (around 6 years old, its a Turbo Max)
Anyway, we powered off the Boilder and emptied the system by connecting a hose to the radiator with the empting plug, opened it up and all the water rush out.
We then replaced the 2 downstairs radiators and both valves on each.
Then from the boiler we opened the water valve and filled it up till the presure reached 1.5bar, then went and bleeded all the rads again, then pumped more water into the system until it became 1.5bar.
Powered up the boiler and it powers up, turn the hot water tap on, i can see the Boiler starting up but then it shuts down and the 0/1 power light just flash's.
i hope some one can shed some light on this issue.
and i'tell you what, i wont be messing with these things again.
Thanks all
Thanks all
