obsolete radiator
11 Aug 2018
Abertillery
I want to remove a rad from my system permanently, do i just put stop ends on about 2 feet of pipe running from flow and return rings? Or is it better to join the flow to the return which wont create air problems?
If you join the flow and return you'll find the other radiators stop working anything like how they used to - you will have created a bypass.
Cap each pipe off individually, use a 15mm micro vent if you want to get rid of the trapped air.
Nozzle
