Oil-based paint over water-based primer?
26 Apr 2010
Cleveland
I renewed some exterior woodwork, which I am going to paint with oil-based paint. I first primed the wood with a B&Q primer which was erroneously described as "solvent based" on their website. When I came to clean the paint brush I realized the primer was water based. Can I use oil-based paint over this primer as this is the same paint that I've used on the surrounding woodwork which didn't need renewing? Thanks for any advice on this.
Oil based paint is fine to use on water based but, if you've only used a primer, you should undercoat before top-coating. If you've used a combined primer undercoat, you can go ahead with the topcoat(s), although more than one single coat of a p/u is always better.
Thanks for that. I've just put primer on so will need to u/c as well. Thanks again.
