- Joined
- 25 Nov 2020
- Messages
- 5
- Reaction score
- 1
- Country
Hello,
First post and I hope the collective wisdom here can help me.
I have an older Euro Cal oil fired boiler connected to a pressured hot water tank and the heating with each rad having a stat attached and the boiler having a digital clock for water and heating.
The system uses a 2 way Honeywell (silver box on the valve head) for the hot water control and a 2 way Drayton ZA6 valve (white box) for the central heating.
Of late the boiler has continued to remain on and the circulation pump stay on even though the clocks have all switched off. I assumed this was a overheat safety think, but no lamps on the boiler were lit indicating this, other than the normal green "on" one. Indeed if I turned the boiler stat down the boiler would stop firing but the pump and the boiler were still active. the valves were shut though and the pump was caveatting.
If I manually then turn the system on again I can hear the valves so as to push water through the system, then turn all demand off again it will after a few minuets all switch off. Sometimes needing a few repeat attempts of this. This is why I thought it was a over heat safety thing, and think perhaps one of the Thermisters on the boiler is at fault or the boiler itself.
However I have noticed that while the boiler and pump are doing this running on thing, all clocks and demand off, if I manually push the Drayton zone actuator lever to the open B position the system will then fully switch off after a few seconds.
At rest (cold) this zone valve also only seems to be halfway between the A-B position and I can not close it any more to the full A position.
Any ideas, new actuator to solve a sticking or stuck or faulty microswitch or is this more of a boiler issue?
thank you.
thank you.
