Oil combi boiler - which is best for the following system
28 Jan 2009
Pembrokeshire
We have one main bathroom, electric shower 2 sinks downstairs but will evetually have an extension with another main bathroom what size would you reccommend and which make? ideally nothing over the £2k mark
any ideas?
which ever boiler you get will have poor performance when you extend your system. look at adding an unvented cylinder to the mix but your budget will need doubling in my opinion.
if thats not possible due to cost you will have to settle for a combi (you wont be able to have both the bathrooms working at the same time tho)
things need checking for suitability.
you need some one out IMO
Most combi's are thermal store type so will provide enough for multipoint draw if the incoming main has sufficient pressure and flow. Generally oil combi's require constant attention to ensure they don't develop leaks. Extra expansion vessels, clean water and a regular change/clean of water filters and AAV's will help.
