I have two rooms (Utility Room and Hallway) where I am considering using an oil based satin on the walls. Essentially I want a hardwearing white paint for the rooms that will stand up to wiping down with a cloth and will put up with mud etc marks from shoes and general wear and tear from children. In addition, in my hallway I have built a custom unit with pull-out draws and this is painted in satin white oil already, so I figure it will make the whole wall more uniform.
Before I do this I want to get your advice on the downsides. I figure on the following:
1. Yellowing - all white oil based paints yellow in areas without a lot of light.
2. Repainting - will be a pain in the rear as I will need to either sand it right back or more likely put a decent undercoat there.
3. Cost - more expensive than emulsion.
Advantages
1. Hardwearing - especially against water based marks
2. Nice finish - I use Sikkens Sutura. It also will compliment my cupboard unit
Any thoughts, am I missing something obvious?
Thanks,
Jon
Advantages
Thanks,
Jon
