Ought to know this myself by now: What's the difference between the Suprima L range and the non-"L" range? They look the same but have many different parts. Were there far more of one than the other?
When Part L came in about 2001 i think it meant the boilers had to be slightly more efficient than they were only about 2-3% and to do this we had to change the fan speeds on differant models and stop them from being range rateable
The only differance parts wise are the fans and air pressure switches
Never replaced an "L" fan or ANY suprima fan? Either way, blimey, I have, thoroughly worn out dry-bearing noisy ones. Not many though, I mean we aren't talking puma fans here...!
Same APS on all of them ?!!! Shame on you. SOme underpaid designer spent ages testing flow rates and you go and use any old thing which works! Which one - I'll make sure I've got one.. .?
