Open vented, radiators but no hot water!!!!
12 Nov 2007
Durham
Hi I have a potterton house warmer55 back boiler I have radiators but no hot water? I was recommended to put the hotwater on only, and as High as possible this seems to work, but only very slightly?
is there anything else that I can do to possibly shift this air block which I got after draining the system???
please help and many thanks in advance.... :roll:
Have you checked the level in the F&E cistern?
When you vented the upstairs radiators do get water out?
Could be valve, limescale, knackered cylinder, sludge, thermostat, wiring. Need a bit more info on what happpens
Boiling it up is your next step but that involves taking fire off to get at boiler stat , so prob need to get someone in.
Try and keep fault all under one heading and don`t open new topic it does help us. :wink:
