Hello,
I have an old conventional heating system. I drained the system to replace old valves. Once all radiator valves were installed the system was turned back on by (Water mains). The heaters are working a treat, the only issue is that there is not HOT water at all. No water is flowing only the cold tap. I only turned off the mains to the water supply I have not done anything else.
What could it be ? (blocked air?how do i sort it?)
My heating system is a old conventional type with one top up tank in the loft and a storage cylinder in the toilet. Boiler and pumpp and everything seem to be working fine...
Please help
Thanks in advance ....
Please help
