central heating is working, but no hot water
8 Nov 2007
Aberdeen
Hi
I have a 20 year old conventional glowworm central heating system (2 water tanks in loft, a hot water cylinder in airing cupboard). The central heating works okay: boiler is working and radiators are hot. However, there is no hot water. To be more precise, the water from the hot water tap is initially hot/warm, but the flow is very small, and after a while the water just completely stops.
What could be the problem? Any advice would be appreciated!
check the cold water cistern in the loft. i bet it's empty.
Hi
If the cold water cistern is empty, what is the cause and how to fix it? thanks.
Are all hot water taps like this or just one tap ? If loft tank is not filling the ball valve is suspect ,replacements are around ten quid.
check it first. there are probably two, one large one that feeds the hot water tank, the other for the boiler. the fill valve is probably stuck , or the feed pipe is frozen
all the hot taps are like this. could it be the motorised valve faulty? It's a Drayton 3 port valve and I saw the black indicator is at "H".
it feeds the hot water cylinder and if it's empty you get no hot water.
Motorised valve has nothing to do with flow to hot taps - water to hot taps comes from tank in loft via cylinder, (where it gets heated by exchange from the coil) and then to each outlet.
Have you manipulated any ballofix/gate/lever/stopcock valves recently?
But as said... just go check the tank... how hard can that be?
thanks for all your suggestions. I checked the loft tank and there is water. The ball valve seems open as I can hear water dripping in from the inlet. I then checked all the hot water taps. It seems the kitchen hot tap downstairs is much better than the upstairs taps where the water flow is a trickle. The water is warm/hot though. I haven't touched any valves lately. Any ideas? many thanks,
The large tank in loft should be around two thirds full ,not just a few inches .Is it ?
