Opti-myst fire transducer problem.
17 Sep 2007
Sheffield
Hi
I've read the useful thread on this but it's now locked. I have one of these earlier type with the blue tank. It has stopped producing mist. On inspection there is a small 'mound' of water above the transducer throwing the odd droplet upwards but no mist. I've cleaned the disc. It looks ok.
Can I just buy the maplin transducer disc at £4 and fit that into the black rubber washer screwed in the underside of the tank? There are a couple of soldering connections but that's not a problem to re-do.
Thanks.
Hi
Thanks.
Hi
Thanks.
I just cleaned the disc inside the transducer with the cheap magical eraser you can buy in the shops it cleaners most metal re screwed it very tightly and it now working.
