Optima compact alarm
12 May 2017
since I accidentally pressed my personal attack button the alarm will not work. The only thing is does is make a clicking noise all the time. None of the buttons will work, it's as though they have been disabled. The only light on the panel is the power on light. Can anyone help me please?
When was your battery last changed? Should be every 5 years max.
Faulty batts. can cause no end of strange faults.
Screwfix before they close!
Does your panic button need reset with a key? can you post a picture up.
Without resetting the Panic then the alarm will do nothing.
As most people dont realise they need a key to turn and reset the panic button, that definitely needs checking first; the battery change is then a definite, even if the key fixes it.
