Hi
I have knocked a dividing wall out between a toilet and a bathroom and need some help regarding the squareness of the walls.
Basically, the wall is not square so I will need to level these out somehow. I would rather not use plasterboard as that would reduce the size but not closed off to this solution.
The entire dimensions of the new bathroom are 2.4m square and one of these walls is about an inch out meaning that I would need to bring it out an inch (maybe less) to get it square.
I was thinking of plastering each wall as they aren't in the best condition (removed tiles, blown plaster etc) so they really need a good skin.
What would the best way be of doing this (will be doing it myself).
There is a window, bath waste pipe and toilet pipe on this wall.
I was thinking about dot and dabbing some plasterboard to this wall to bring the actual distance I need to plaster down a bit, is this a good idea? Otherwise I could just plaster and big thick amount and level it up using battens etc.
Ultimately it will be tiled (probably floor to ceiling) so I don't know which way to go, plaster or just do the plasterboard method and then use grout to bring it up.
Any ideas?
Any ideas?
