know doubt a ? which has been asked many times. I have a spar dashed external wall and there is blown rendering (about 6 inches) down to ground level. I have chipped all away to the brickwork. I am going to re-render after I hopefully get knowledgeable advise.
1) do I PVA brickwork first - what mix and would one coat suffice
2) sand/cement mix - do I use a mixture of builders / sharp sand what ratio. DIY Manuals quote a lime type of additive ( does this make for a more water proof finishing ) looking a weather extremes ie heavy rain / frost in the winters.
3) lastly deepening on thickness do I need to do a scratch coat and is PVA needed on all coats
Many thanks in advance a quick answer to the 3 questions kind regards John
