im am currently installing a pump for a water feature and also so low voltage lighting in the garden, i have run a length of 2.5mm swa from DB to a MK 2 gang water proof switch on the outside wall at the back of the house, i plan to run some 1.5mm flex from this switch to the lights and pump all the flex will be under decking i am putting down.
Is it exeptable to just run flex under the decking or does it need to be swa?
thanks
Nick
thanks
Nick
