    Dismiss Notice
Output from Dynamic Phrase Synthesizer/Loop Recorder
Discussion in 'Audio Visual' started by imamartian, 3 Nov 2010.
  1. imamartian
    imamartian
    23 Sep 2007
    8,994
    Thanks Received:
    55
    Derbyshire
    Country:
    In other words, how do you connect speakers to a Kaossilayor Pro?
    (http://www.korg.com/product.aspx?pd=564)
    it has:
    - a usb output
    - a midi out
    - rca red and white (stereo audio) connectors
    i suspect i can use a usb and play through my laptop? or the rca cable through a stereo? but is there a way i can play it through a guitar amp?
  2. Sponsored Links
  3. ChrisFrost
    ChrisFrost
    26 Aug 2009
    1,025
    Thanks Received:
    213
    Cheshire
    Country:
    depends if the guitar amp is mono or stereo capable.
    With stereo capable it's easy. Get a phono to jack lead.
    If the amp is mono then you may need some sort of mains powered converter to bring the left and right together properly as a mono signal before connecting to the amp.
  4. imamartian
    imamartian
    23 Sep 2007
    8,994
    Thanks Received:
    55
    Derbyshire
    Country:
    thanks Chris, not sure if the amp is stereo, but suspect it's not... it's a line 6 basic amp.
    Any idea how else i can get sound out of the Kaossilator?
  5. ChrisFrost
    ChrisFrost
    26 Aug 2009
    1,025
    Thanks Received:
    213
    Cheshire
    Country:
    Yeah... Phonos which is another name for - rca red and white (stereo audio) connectors
  6. joinerjohn
    joinerjohn
    28 Nov 2009
    6,145
    Thanks Received:
    201
    Derby
    Country:
    Martian, Have you tried RTFM? (reading the f****ng manual) ;) ;) ;)
    Surely this will show you how to connect to an amplifier and speakers.
    Having said that, some manuals for music equipment these days seem to assume the buyer/owner will already know how to do these things.
    Try page 6 of this PDF document., http://www.korg.com/uploads/Support/KAOSSILATOR_PRO_OM_EFG1_634067737513300000.pdf showing the connections.
    Seems it connects to either an amplifier/mixer or active powered speakers.
    Must admit I like the vocoder facility of this unit. ;) ;) ;) ;)
  7. Sponsored Links
  8. imamartian
    imamartian
    23 Sep 2007
    8,994
    Thanks Received:
    55
    Derbyshire
    Country:
    Calm down dear, it's only a forum ;)
    no i haven't read the manual because it's not been delivered yet !!
    But thank-you for the link... i'll have a butcher's .
  9. joinerjohn
    joinerjohn
    28 Nov 2009
    6,145
    Thanks Received:
    201
    Derby
    Country:
    Strictly tongue in cheek Martian.
    I'm well into music and music technology ;) ;) ;) ;)
  10. OwainDIYer
    OwainDIYer
    5 May 2010
    4,536
    Thanks Received:
    694
    Stirlingshire
    Country:
    Or you use a couple of resistors to sum the left and right signals into mono. Bit of a cludge but then if it was proper kit it would be balanced line on XLRs.
  11. imamartian
    imamartian
    23 Sep 2007
    8,994
    Thanks Received:
    55
    Derbyshire
    Country:
    finally plugged the phono (red and white leads) into my surround sound... sounds good with great bass.....
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
