Oven not working
26 Oct 2011
Derby
Hi there i have a stoves 600gr double oven. the grill and hob work fine but the fan oven at the bottom will not work at all. no light no fan and no heat. the grill doubles up as a oven, the grill works but the oven will not. any idears?
If the timer is not set to auto, then I would expect it to be the thermostat or element.
(It may have an internal fuse)
no the clock is not working at all. it did work and we have used the timer before and it worked fine. the clock started working intermitent for about a week. but now it is not working at all
The live feed to the clock may have broke, this will also be linked via the timer to the fan oven.
If you can get to the timer, have a look, REMEMBER TO SWITCH POWER OFF.
If you arnt competent you may need to call someone out for a repair.
