Overdoing subfloor?
11 Sep 2007
Im installing 20mm oak tng flooring with underlay. secured with tite screws.
the existing subfloor is 20mm victorian pine boards in pretty good nick and fairly level.
rather than spend the money on new ply, im going to use the existing floorboards and sand them.
they run perpendicular to joists. as will the new boards i lay on top
so should i lift old boards and relay at 45 degrees to joists so that there is some offset between them and the new boards above?
or is that overkill?
many thanks and apols if this has already been covered.
What a complete waste of effort. You'll probably struggle to lift all the old boards without breaking at least some and if you are changing orientation that way the sub-floor will become a lot bouncier (because your joist centres are effectively secured at 1.4 times the distance, assuming a 45° angle). You'll also need more timber to accommodate the change in orientation, mitre cuts, etc. As a joiner to my mind that is a complete non-starter. The way to do this is not to waste time, effort and money attempting to re-invent the wheel - it's to do it the established way and overboard with plywood screwed or nailed at 150mm centres
Why not sand the floorboards, then oil them? Less expensive and it won't look fake for the house.
thanks both
existing boards arent up to a refinish. I'll use them as a subfloor with a lot of new screws and try to keep it authentic with the new boards.
