Hi all,
Changed the piston in the header tank at home a few weeks back as the overflow was leaking, but it's started leaking again. Assuming that the piston and washer haven't failed in six weeks, any thoughts on what else might be causing it, or what to check when I get home. Isn't there only one inlet to the header tank? Other half had taken a shower when it started if that helps at all, and the system is a standard potterton profile e50 bolier.
Ta muchly.
Ta muchly.
