I have a Potterton Prima which is fed from the header tank in the loft. Recently the header tank has started to overfill and then flows out of the overflow pipe.
I have managed to work out that the ball cock isnt leaking, nor is the overflow pipe which goes in at the top. Therefore it has to be the pipe at the bottom which feeds the system... but why does it fill up the tank with water?
I understand from a post by someone earlier today that it is normal for warm water to come back up through this pipe?...but surly not at the rate mine does (at the moment I am having to siphon out around 1 washing up bowl every 2 days to stop it reaching the overflow level)
Any help / suggestions would be appreciated.
