Hello all,
Have something of a house of horrors with regard to painting
. Have two problems, though they may be connected.
The first problem is with paint adhesion. In the hallway, living room, bedroom and ensuite I have encountered a situation whereby the application of a coat of paint to the walls causes a 'bubbling' behind the existing coat, which then lifts from the plaster and peels off the wall like a sheet of thin rubber
. The hallway and bedrrom both had wall paper stripped before painting, the ensuite had painted walls. In each case, the walls were sanded and sugar soaped. When the original paintwork was completely stripped back to the plasterwork, the palster was sealed with plaster sealer before reapplication of paint. Any ideas about what is causing this as prepratory work does not seem to prevent it
Secondly, the paint to these walls has a tendency to split. Sometimes there is only a small area which looks like a series of hairline cracks stemming from a central point. However, the ensuite has a large section next to the window which looks like an aerial shot of very hard baked mud - lots of fracture lines, no particular point of origin. Previously, treating the cracked areas with plaster sealer before repainting cured this problem, but it has reoccured in the ensuite. I'm using reasonable quality B&Q paint for all these jobs. Anyone know what I'm doing wrong?
Thanks,
Adam
Thanks,
Adam
