paint setter for inlay in wood carving
24 Feb 2014
Yorkshire
hello im new here and i need some advice and was hoping some of you guys could help me out.
im making a modular paddle strop and am carving a vine into the sides of it and i want to inlay the carvings with some water based acrylic pain i have.
the paint is too thick so i need to dilute it at the moment im using water for testing purposes.
the problem is when it sets its still soft and can be easily marked with a fingernail for example.
so i need some kind of setter/hardener which will cause the paint to set hard after pouring it into the carving.
does anyone know of anything that will fit the bill?
i will be going over it with clear varnish/lacquer when it is hardened.
thanks in advance guys
kindest regards steven
I would have though a polyester clear resin that's mixed with a clear hardener would be a better option.
And colour it with the acrylic paint.
thanks for the reply how about epoxy resin and hardener?
the only problem is i dont think the epoxy mixed with the paint will be runny enough to pour into the engraving unless i added it bit by bit but then it wont be flat like it would if i poured it.
i have a very well known good quality one, there are no ads allowed on this forum as it says in the rules but im sure you can figure out which one im talking about im not sure if its polyester based though
also what percentage of paint do you think i can dilute it with i want the exact colour of the paint but it needs to still be hard
