painting on lining paper
6 Oct 2008
Down
I recently got the main wall in my downstairs hallway lined to hide a sheen that I had already tried to disguise. I had assumed my failure to do so was because of the paint work left by the previous owner. I stupidly forgot to ask the decorator if I could use vinyl silk paint straight onto the paper (1000 grade). I used silk as this seemed to be recommended for high traffic areas. After 2 coats the wall is still very patchy, as bad as it was before. Is there a simple solution to this, whilst still using silk paint.
Did you thin the first coat a little?
No I didn't, I realise now I should have done. Is it too late to apply thin coats at this stage
Friad so..
Thinning it a little allows it to bite into the lining paper as opposed to just sitting on the surface, this might have cuased part of your problems because the absorbant surafce would stop you from moving the paint around easily..it would be sucked in fairly quick and this causes an uneven amount of paint on the surface
Also..did you use a bursh or a roller?..silk is notorious for showing up every single mark on a wall..you might find the solution is soft sheen or acrylic eggshell
I used a roller. Yes I am beginning to realize how difficult silk is to use if your an amateur. Could the soft sheen be applied straight or would I need a lot of sanding to remove sheen before I start.
Id give it a light rub down first just to remove any nibs etc..then go straight on with the soft sheen.
You shouldnt have to, but if you think its pulling a bit and dragging when your cutting in then add a drop of water to it.
