Painting over previously stained skirting boards - primer vs zinsser
24 Mar 2020
Hello,
My house currently has pine skirting boards and architraves which have been stained with some almost orange coloured stain. As you can imagine it is hideous and i want to get rid of it. The skirtings and architraves are all about 20 years old and have been installed since house build. I have rubbed back all the skirting boards with 120 grit and have now given an initial coat with Leyland Trade Wood Primer. However, subsequent to putting this initial coat on, i understand that i should have first coated the wood with something like Zinsser Bin to prevent bleed through and knots leakage. To avoid me having to completely strip the skirtings back, could i key back the initial coat of leyland primer and then apply a coat of zinsser over this? Would this then provide a good base for any subsequent undercoats and top coats? Thanks.
If you don't mind waiting, do one coat of finishing paint and leave it for a few months.
Then you'll see which knots need treating.
Sand only these points down to the wood, use a knotting solution and then primer and paint.
To finish it off do the second coat to the whole skirting.
Basically, delay the second coat of paint.
