painting with zinsser BIN
  • Thread starter Thread starter HS4
  • Start date Start date
HS4
3 May 2012
Carmarthenshire
I'm about to start painting ALL the woodwork in house, 1930's doors taken back to bare wood, new skirting boards etc. Have been told i can use a small roller for the flat parts of door. Is that correct.
Any tips on using BIN.
Any help would be good thanks.
Best thing is to take it back and use the much cheaper and easier to apply Leyland Acrylic Primer/undercoat. Brushes and rollers wash out in water too.
  • Thanks
Reactions: HS4
Thanks Joe-90
But I'm using Bin as I then don't need to use notting. The info on notting says not to use water based paint on top.
Unless your knots are very resinous (when aluminium primer is best) you shouldn't need knotting. Just Acrylic primer/UC.
