    Dismiss Notice
Panasonic Heat Pump tumble drier
Discussion in 'Appliances' started by Paul-man, 11 Jul 2019.
  1. Paul-man
    Paul-man
    1 Jul 2007
    288
    Thanks Received:
    2
    Essex
    Country:
    Our 5.5 yr old heat pump drier has stopped working. Drum rotates but machine doesnt warm up or extract water. Wife observed an error code of H86. Panasonic helpdesk useless- put me in touch with the only registered UK service centre in Warrington, who, were not interested in helping me in Essex.
    I'm hoping someone may know or give a rough prognosis. Is this a write off, or should I pursue trying to find someone?
  2. JohnD
    JohnD
    15 Nov 2005
    74,135
    Thanks Received:
    4,282
    Crossgates, Europe
    Country:
    Cook Islands
    Sometimes there is a vessel that gets clogged with fluff-and-water paste. On some Bosch machines there is a "secret hatch" not mentioned in the instructions to access and clean it.
    You need to quote the model number, a search on that might find someone who knows the fix. a local repairman who does a lot of these machines may know the answer without having to search. This is more likely if it is (was) a popular machine, such as a "Which" best Buy, when it was new.
  3. Sponsored Links
  4. foxhole
    foxhole
    14 Mar 2006
    17,980
    Thanks Received:
    2,060
    Kent
    Country:
    H code refers to non customer serviceable item.Probably overheat switch tripped.Can be diy'd with a little knowledge.
    generic video.
    or you could try
    http://khwashingmachinerepairs.co.uk/
    Kent side but may come to you and exceptional service, no inspection fee, no fix no fee.
  5. Paul-man
    Paul-man
    1 Jul 2007
    288
    Thanks Received:
    2
    Essex
    Country:
    Thanks both. I had already searched Google by model number. Unfortunately, it's not a popular model.
    Thanks foxhole for the link and video - will give them a try. I'll take a look in the back first if I can. Have successfully repaired washing machine and dishwasher in the past so if there is a simple red button to try, it's worth it. I fear that parts for my machine might be an issue.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
