- Joined
- 27 Jan 2008
- Messages
- 29,661
- Reaction score
- 3,669
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
OK that tells me a lot. If I explain how it works then maybe you can work out the fault. It is in essence a switch mode power supply and what it does is switch on and off very rapid and it varies the on to off ratio. The time on is called "Mark" and the time off is called "Space" hence why it refers to the Mark/Space ratio.
Likely there is something like a 555 timer which in turn switches a FET or other type of transistor.
The main advantage of this type of control is the heat generated is low. First developed for front loading VCR machines because of the cooling problems it has grown to everything from welding sets to mobile phone chargers.
However they are very hard to repair. Unlike the standard power supply you can't follow the progress with a meter and find the problem in real terms the way to repair is to swap bits until it works.
Much depends on cost of unit in first place. A 555 timer costs a few pence and what I did was to swap the chip for a IC holder then try a new chip. If it was not the chip I could remove the good chip as not soldered. With a card costing £100 swapping the 4 chips first was worth the risk but with a card costing £5 it would not be worth time and possible throwing good money after bad.
It will require using a solder sucker to de-solder all the pins which if you are into electronics may be worth while but unless you are reasonable with soldering iron likely not worth the effort.
From what that PDF says it does not measure the back EMF but likely it will want a reasonably smooth supply. With the small transformers you put into the wall often there is no smoothing. So step one try powering from a battery. One of those lantern batteries should do.
If it works from a battery try sticking a large electrolytic capacitor across the output of the power supply. It may work. Having a power supply switching on and off as it will do if either a switch mode or simple rectified is going to really mess up a device trying to work a timer.
It may not be a 555 could be a 74121 or even a simple 741 op-amp but likely the charge time of some capacitor is what sets the mark space ration so it really does need a constant supply.
If it works on a 996 battery then may be worth while using a small lead acid like those used in alarm panels.
Do let us know how you get on. I was it seems right when I said a multi-meter would not really help.
