I have recently installed a modern panel radiator in my new bathroom. Like this one here https://images.app.goo.gl/SupNdVUfbBQrQkjW7
Problem is only two of the vertical elements are heating up (one at each end) the top and bottom tubes are also hot.
I've bled the radiator using the bleed screws at the top and only water comes out. I've tried fitting a hosepipe in place of the bleed screw, closed the return valve, and then swapped sides. Still no good.
Any more suggestions?
