My fathers house is a semi, builders are working next door to convert it to a series of flats, surveyors have met to agree a Party Wall Award - which has not yet been agreed.
The party wall is a standard two bricks width - on his 1930\\\'s semi.
The builders have already bedded in the steels and have removed most of the chimney breast.
They have now set about chasing channels in their side of the party wall - so they can embed 40mm grey plastic drain pipe - I assume from sinks yet to be installed).;
They have used percussive tools and have knocked a brick through onto my mums wooden china cabinet, where they have been making this channel.
The channel is cut both vertically and horizonatlly, where it runs horizontally (about 0.5-1.0 metre) one whole bricks depth has been removed, backfilling with a 40mm plastic pipe and cement surely must compromise the strength of the wall.
Also when the pipe is in use myn parents will have to endure the noise of water through pipes in all their rooms (as they are cutting channels on in all rooms their side near to the spine wall).
This type of noise will be like chinese water torture.
Can my parents stop them embedding plastic pipes in the wall, I have never seen anything like this before in conversions, surely the pipes should be in pipe clips on the surface of the wall.
