I need to install 6m of ducting in my ceiling. Between two joists over two rooms. Sadly there are already lost of pipes and wires up there so I am going to have to take some of the plaster board down to find space for it all.
How would you go about this? It looks easiest to just remove the plaster board from between the two joists required and then replace after. But I wonder about how visible the job may be and the possibility of cracking after as all joint would like up. Is there a better option?
