Hi, will be installing a shower next week and will be using a thermostatic mixer(combi compatible) which has 15mm inlets for hot and cold.
I presume that I'll be ok using 15mm pipe throughout to plumb this in but someone advised me that I must use 22mm pipe as per bath or flow will be poor.
If this is the case, do i need to use 22mm pipe and then fit reducers at the mixer? Can't see that this would make any difference though. From what i can gather, 22mm is necessary when using a gravity fed system.
Also, i presume that it is a good idea to fit isolating valves on the hot and cold supply to the shower. Is it best to use inline or gate type valves?
Many thanks, Chris.
Many thanks, Chris.
