I have a 210L unvented cylinder with a 22mm feed coming out of it, connected to (in order)
- cloakroom hot tap (15mm tee)
- kitchen hot tap (15mm tee)
- bathroom shower (22mm tee)
- en-suite shower (22mm tee)
A plumber (looking at something else) told us that we might get a better flow rate if we upgraded this "backbone" pipe to 28mm.
I can't see how this would make a difference: the hole in the cylinder is still only 22mm, as are the feeds into the cylinder - so won't that just be a bottleneck?
Can anyone explain if there is a benefit?
I can see it might make a difference on the cold supply as that's 32mm MDPE, unbalanced (the shower valves have built-in balancers).
Thanks,
M
Thanks,
M
