Plaster boarding before tiling
2 Apr 2022
I'm cutting out some plasterboard that has tiles on, and replacing the plasterboard before re-tilling.
I don't intend to skim the plasterboards as it will have tiles on, however the old plasterboard does have a skim on it. Once I replace the boards there will be a slight difference in width, with the old plasterboard having skim and the new not.
How do you recommend I make both flush? Should I pack behind it and with what as its only a couple of mm or what method do you recommend?
