plaster crazing due to heat!
1 Aug 2006
I recently installed a multifuel stove. I knocked out the chimmney breast and set my stove in the bottom of the chimmney breast. I dry lined the back and surrounding areas and within a month or 2 the plaster started to craze and crack due to the intense heat. I now realise that i should of maybe made the opening bigger to allow the heat to escape a bit easier but it is a little late now to alter the building work. Are there any suggestions on what i could do . Is plasterboard worse or better than old fashioned browning/bonding then skimming or is there a better way for the plaster to stand up to the heat.
next question where do you get heat resistant plaster from then. Do any of the main line merchants stock it like travis perkins etc
There is a phone number for "Envirograf" (the manufacturer) in the lower link above from Richard C, that will give you details of your nearest stockist.
Roughcaster.
