Plasterboard onto breeze block wall
21 Dec 2007
Essex
Hi, I have a breezeblock shed and I want to line the walls with plasterboard. I was wondering what the easiest and cheapest method would be. Is there a type of screw that could be screwed straight through the board and into the block without the need for rawl plugs or wooden battens. Thanks
If your not worried about insulation, just glue it, building merchants will have bags of powered plasterboard glue, mix with water and whack it up. Its a lot stronger than it looks too.
