Hi I'm about to take on my first try of dot and dabbing...
I'm going to do the ceiling first which i'm screwing to the joists, no overboarding.
My ceiling height is 2470mm and the plasterboard is 12.5mm thick on ceiling. My questions are
1) do you board the ceiling right up to the walls or do you leave the gap for the wall boards?
2) what do you do about the difference in height? i.e. the wall board is 2400mm x 1200mm and my ceiling is 2470mm so there is a 70mm gap. maybe 15mm less depending on the answer to the first question. Do you put 70mm of board at the bottom of the walls?
