ok, im very confident in plastering...... although I do have a question as to how to plaster 120 degree angles....... or at least what looks like a 120 degree angle, give or take a few.
which is if you picture it...... a normal 90 degree angle plus a bit more,........ like sloping walls in loft convertions?
the goal of this is to achieve as straight a line as possible along the ceiling line and the sloping angled wall running down from it,
in the past i have spent a long time doing it successfully by eye and hand, brushing it in etc, this time im thinking of running a skim stop bead along the ceiling line and plastering off the bead and achieving the straight line.
you do get trowels that shape but ive not seen one in any merchants or even online, but my journeyman had one ages ago, never used it tho but im sure its a 120 angle
even without wet corners it it difficult to get the straight line, anyone who has tried this will know,
i can do it, it just takes a lot of time and im just sure there is another technique to this, i recon the stop bead will do the trick although there must be some other way?
thanks for any input
