Hello I am about to plasterboard a stud wall and plaster it and I am after some advice. I have worked with Gyproc multifinish plaster to patch holes but not to skim a wall. The walls I will skim are in a hallway and possibly a bathroom (depending on what PB or tile back board I can get) that will be completly tiled over.
So do I need to do 1 coat or 2 coats of plaster?
Do I need to fill in indents where the screw heads are before plastering?
Can I plaster straight onto plasterboard or do I pva first?
And as far as I know the process goes:
build stud wall
screw in plasterboard
tape the joins
knock up plaster and apply a coat of 2-3mm
Give it 10 minutes and level out coat
give it a further 20 minutes and splash with water and polish
Now I am pretty new to this so please tell me if this is wrong. I have patched up bits before and all seems ok but a wall is a whole new boat
1 last question. All my patch up jobs have been left slightly bumpy. This has been rectified with a slight filler/sand. Is this just my polishing technique not up to scratch yet?
Thanks for any feedback, you guys have helped me heaps already
build stud wall
tape the joins
