I hope someone can help me. My boiler is a Worcester Junior 28i. We have had a problem with the water pressure dropping for no apparent reason. It drops below 1 bar, the red light on the boiler starts flashing and after a while, no matter the amount of stopping and starting, we are unable to get heating or hot water. I have a British Gas Homecare Agreement and I each time it gets this far I call them out. They remedy it temporarily but it happens again. Each time they come out, I ask if there is a leak or what might be causing it but they basically just say it's not a problem. Now the water pressure has dropped to zero and the red light is flashing. I have tried using the little taps at under the boiler to increase the water pressure like the engineer showed me but there doesn't appear to be any water in the system to increase the pressure. Basically, when I turn the peg, nothing happens. Does anyone have any suggestions, or in the least any idea of what I might say to the heating engineer so I don't get fobbed off again?
Thank you in advance.
