plumbing and heating trouble
Dude, I am far too hungover to pass judgement on anything more than a morning tu7d.
Don't forsee things changing until Sunday evening at the earliest :mrgreen:
well after soldering all the new pipe work and getting it all done i put the water back on and yes you guessed it .... leaks :-(((( i was not amused so after looking at other options i took it all off and used compression parts. one of the other valves started leaking so i replaced that as well. i have bled all the rads and fired it up and low and behold it has done the trick ! :-) (which made me very happy) had a fair few miss haps but got there in the end. i have turned the boiler down as the pump seemed to be getting hot. the pump is running on number 2 and the boiler is on 3 and a half. i know the pump will get warm but how hot should it get ?
all the best
lee
Well done.
Pumps can get very hot.
Cheers Dan. all still seems to be well but i have a constant dripping sound in my ear lol ...... just want to say thanks to you as well :-) been a great help dan so thank you. and thank you to everyone else who posted on this ! much appreciated.
i might take a course in plumbing i loved it so much .............
thanks again
lee
Good effort.
and thank you !! you were spot on the 15mm pipe was really blocked up i couldn't even put a screwdriver through it.
thank you ! i will post a pic so you can see how a real cowboy gets it done ;-)
all the best
lee
here are a few pics :-) where the pipe comes of the pump i had to use a bit of ptf tape but apart from that it is still going fine :-) thanks again you lot !! :-)
