Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Probably. 1/2" is slightly bigger than 15mm. The olives will fit, but sometimes the body of a fitting is too tight. I suggest you pick a manufacturer and give them a call.
NB if your system is that old it may be a single-pipe system, where all the rads are in series. If it is, you need special trv's.
