Hi I'm about to over board an old battered T&G floor that I have re-patched which is still a bit bashed & dinted etc. It's a complete house renovation so can use pretty much any thickness ply as no need to match any other heights so was thinking maybe 12mm or so ply?
As well as fixing the ply to the T&G I'd usually screw through to the joists for extra strength, however I've seen on a few U.S sites they recommend you ONLY screw to the T&G to create some kind of slip layer??? I've never heard of this before so wondering can anyone shed any light on the subject?
Heres a few quotes I've seen on the U.S sites:
"You will fasten the planks with screws to the joists, then fasten the plywood to the planks not into the joists. I know it sounds goofy, but in reality the plywood will "slip", and you are allowing it to do so by not putting it firmly into the joists. Your planks become part of the joists, and the plywood becomes part of the planks."
"With two layers of subflooring, they have to be given the opportunity to "slip" against each other, although, granted, this slipping is minimal. Fixing both layers to the joists prevents any possible movement in the top layer."
