How much force should the impeller have? Does my system use only this pump?
After reading a substantial number of articles, the story is as follows:
System: Grundfos 10-50 pump drawing water from Netaheat 10/16 boiler, 1988. 3-way valve afterward feed heating coil and CH circuit. Microbore pipes to rads.
Rads never seem to have had cold spots, the system has had inhibitor and has been looked after reasonably well.
For some time boiler (netaheat 10/16 c. 1988) has cycled on/off when heat was in demand. Mostly ignored because the house was warm enough and hot water was fine. Boiler outlet pipe gets very hot no problem.
Finally checking why some rads were just luke warm necessitated hasty gate valve replacement because the old ones leaked when actually utilised!
Pump impeller seemed to rotating at all 3 settings.
3-way valve controller is removed to have manual control of HW/CH flow. Internally checked to ensure flow is ok.
Drained system through kitchen rad and left it for a while. F&E tank seemed fine because water was in continual supply (30 or 40 mins of flushing).
Refitted pump and refilled, along with anti-sludge chemical, bled rads. No improvement.
Separated pump housing in-situ and found impeller completely blocked with detritus. Cleaned completely and really assumed the lack of pressure would be fixed. I also checked the 'torque' of the impeller; It took reasonable pressure (with a towel-in-hand) to stop it on position 1. Position 3 was pretty forceful, bring to mind a disc brake. it could be stopped but really felt like it was enough to do the job.
It did not fix the system problem though. I will buy a pump if it were the pump but the force seemed ample and the impeller seems fine. It is a solid metal affair with surprisingly small impeller width (5 mm max). The flow enters the centre and is impelled outward. I did notice that the impeller moves on its spindle more than i would expect; might this take it away from the 'input' water supply and reduce the flow pressure? There is no sign of a 'tight' fit mechansm to ensure that no flow goes around the impeller. Is there a part missing that has disintegrated perhaps?
Now, the rads upstairs grudgingly get warm, even hot eventually, like before. The boiler still cycles. Only one downstairs rad finally heated to warm, others are stone cold. All were bled of air. I tried bleeding a radiator downstairs with one side valve off and bleeding a lot of liquid (because I read it in one of these articles). I expected hot water, eventually. After more than a litre I stopped and swapped to the other valve.
This is the interesting part; the water stopped! No flow at all after half a litre or so. Does this mean I have a air block between the upstairs and the downstairs? The system has been drained a few times in the past without this problem occurring. I repeat, the F&E tank still had water in it after flushing and the upsatirs rads did not drain to the downstairs bleed valve.
I think some pump flow occurs, the boiler water arrives faster than convection would seem to allow allow. However, the water flows into the hot tank (air screw also bled at that point). The outflow takes some time to heat even if the pump is on 3.
So, finally, any ideas or just replaced the pump and hope?
cheers, Ivan
cheers, Ivan
