B
BigBurner
You're right Simon, that was a typo. It's an Ecotec 937 (a monster of a boiler!).
I'll post back details of the flow rate when I get them. Which taps should I measure this at? And what's the easiest way of measuring it?
Firstly fit a "full-bore" mains stop tap to reduce a major restriction, and then test the flow rate at the kitchen tap in litres per minute.
If the flow rate is then acceptable, it is then better fitted with a dedicated 22mm pipe from the cold inlet to the mains stop tap, to give the combi priority and reduce water resistance.
Then fit isolators on each appliance: basin, sink, etc, and turn these down to suit balancing the water system. Keep the shower and baths fully open.
