pop up waste problem
7 Sep 2008
Yorkshire
hi, i have a pop up waste on a bath that has worked lose , does anyone know how the silver section that you twist is fitted. I need to demove it but it is well stuck !. Are they normaly screwed onto a shaft or a push fit as it wont seem to budge. Any ideas ?
Should be a hole in the bottom of it to insert your screwdriver and unscrew it off. :D
If no hole, it should pull off, but they are hard to push on so will obviously take some effort to get off...
good luck :wink:
(just understood previous post....waffled a bit :oops: )
