- Joined
- 25 Jun 2024
- Messages
- 2
- Reaction score
- 0
- Country
(Apologies if this is the from forum section -- I couldn't find an alternative section that looked more suitable.)
I have a portable 'single unit' air conditioner, which I think is basically an unbranded version of this: https://www.aircondirect.co.uk/p/10...itioner-with-heat-pump-for-rooms-up-to-40-sqm
It's probably 6 or 7 years old. I've used it most summers, on full whack for about 5-6 hours a day, without any problems.
Yesterday I turned it on for the first time this year, and it started working fine as usual. But after a couple of hours, it died. No fan spinning, no compressor sound, no lights on the display, unresponsive control panel, just dead (as if it wasn't receiving power). I have been unable to get it to turn on since.
Obviously the first thing I did was to check the (13A) fuse in the plug. The fuse is fine. (I even replaced it with a new fuse, which made no difference.)
So my question is: is it worth the time/hassle/cost of trying to get it repaired? On one side, I'm loathe to chuck it away and spend £500 on a new one if a repair would be cheaper (and less wasteful). On the other side, I have no idea what might have failed, or whether or not the failed part is even replaceable, and I don't want to waste time and money locating and calling out a suitably knowledgeable repair person if it's likely a lost cause anyway.
