Hi - the overflow from my cold water tank was dripping for some time, always mornings after no hot water use overnight so I replaced fibre washer and piston washer but it still dripped so I've replaced the ballcock.
As the new one appeared to be the same as the old one and the existing inlet section seemed as though it may be a pain to get off I've just swapped a new front section (valve case and lever arm) for the old one - seems okay - any views ? and would you advise PTFE on new threads where old nut joins or should it be okay ?
